I have a part that I want to use: https://www.digikey.ca/product-detail/en/phoenix-contact/3044542/277-3310-ND/2426251
I've added this part with one circuit and four terminals. This terminal block as you can see has 4 terminals on one circuit. I don't want to create a symbol with 4 terminals, as I need to separate the part across pages and have no interest in using origin-destination.
What is my best option? If I split the part to have two circuits with two terminals, then I lose connectivity unless I go into the TB and manually assign a bridge.
Thanks in advance.
This is something that I wish could be split, it's one of my top requests for SW to make multiple symbols attach to a single circuit. In any case, you may be able to do this: I'd model it as 4 circuits, each with 1 terminal. Then in the symbol settings that you are using (maybe create a copy of an existing terminal symbol?) , assign a "hyper passing" type of information transmission to the symbol's circuit. This will let the part's terminals be "internally connected" to pass the equipotential information.
