Is there a way to connect 2 radius leader lines like in the first picture rather than like it is being done in the second picture?
The first picture was done in solid edge and I am recreating some drawings in solidworks 2019
I've always had trouble with this but there is a workaround.
First place your dimension normally on one of the features you want to dimension.
Next Create a note with the leader pointing to any of the features you want to dimension.
While in the note, click on the original dimension. The text will be copied into the note.
Now hide (not delete) the dimension, it will update if the model changes.
Now right click on the note leader and select Insert New Branch.
Place your second leader.
After you've placed your leaders you can adjust the positioning of the arrows and leaders by left clicking on the leader
and dragging on the boxes.
Hope this helps.
Hope this helps.
