Hey Solidworks Community,
I'm hoping you can help me on a loft issue I'm having. I have designed a flying wing that is going to be the "plug" to create mold halves for composite manufacturing.
I have two airfoils that I am lofting between with 2 guide curves. The issue is that right at the trailing edge there are weird geometries created such that creating a parting line and surface is difficult. I'm assuming it has to do with dimensioning and locating the airfoils(curves/spline) and guide curves.
Any help would be appreciated!
..the closed curve (not very accurate) and it is coming to a extremely sharp point and it becomes distorted (if it were analytical it would be clean).. so, the quick solution is cut back that distortion (image).. or trim back the sketches so they are clean. like the cut, not closed.
