Hello. I've written a macro to supplement the custom properties builder that modifies a template part according to user input. But I've noticed that it doesn't work as expected when I try to edit the part in an assembly and run the macro from there (it doesn't perform any of the changes and triggers the "Base color not yet supported" message I've built into the program. I assume it has something to do with what SW is considering the active document, but I'm not sure. Is there an easy fix for this?
'Declare Variables
Dim swFeatureManager As SldWorks.FeatureManager
Dim swModelDocExt As SldWorks.ModelDocExtension
Dim swCustProp As SldWorks.CustomPropertyManager
Dim swFace As SldWorks.Face2
Dim WireSize As String
Dim WireSelectState As String
Dim UserSizeSelection As String
Dim swEquationMgr As SldWorks.EquationMgr
Dim ValOut As String
Dim PropName As Variant
Dim IDNewValue As Double
Dim ODNewValue As Double
Dim BaseColor As String
Dim StripeColor As String
Dim ConfigSelect As String
Dim ConfigStatus As Boolean
Dim AppearanceFolder As String
'Set Variables
Set swModel = swApp.ActiveDoc
Set swModelDocExt = swModel.Extension
Set swFeatureManager = swModel.FeatureManager
Set swCustProp = swModel.Extension.CustomPropertyManager("")
Set swEquationMgr = swModel.GetEquationMgr
WireSelectState = swCustProp.Get("Wire_Select_State")
BaseColor = swCustProp.Get("Wire_Color")
AppearanceFolder = "V:\AAA\AAA SolidWorks Templates\Antaya Appearances\"
'Set OD & ID Global Variables Based on WireSize
Select Case WireSelectState
'For Selection by Part Number
Case "0"
MsgBox "Part Number selection not yet supported"
'For AWG Selection
Case "1"
WireSize = swCustProp.Get("Size_AWG")
Select Case WireSize
'Each case relates to a wire guage provided by the user in the "Size_AWG" custom property
Case "10"
'Set ID 2.59
'Set OD
IDNewValue = 2.59
ODNewValue = 4.59
Call SetEquationValue(swEquationMgr, "ID", IDNewValue)
Call SetEquationValue(swEquationMgr, "OD", ODNewValue)
Case "11"
'Set ID 2.3
'Set OD
IDNewValue = 2.3
ODNewValue = 4
Case "12"
'Set ID 2.050
'Set OD
IDNewValue = 2.05
ODNewValue = 3.5
Case "13"
'Set ID 1.830
'Set OD
IDNewValue = 1.83
ODNewValue = 3
Case "14"
'Set ID 1.630
'Set OD
IDNewValue = 1.63
ODNewValue = 3
Case "15"
'Set ID 1.450
'Set OD
IDNewValue = 1.45
ODNewValue = 2.8
Case "16"
'Set ID 1.290
'Set OD
IDNewValue = 1.29
ODNewValue = 2.5
Case "17"
'Set ID 1.150
'Set OD
IDNewValue = 1.15
ODNewValue = 2.3
Case "18"
'Set ID 1.020
'Set OD
IDNewValue = 1.02
ODNewValue = 2.2
Case "19"
'Set ID .910
'Set OD
IDNewValue = 0.91
ODNewValue = 2
Case "20"
'Set ID .810
'Set OD
IDNewValue = 0.81
ODNewValue = 2
Case "21"
'Set ID .720
'Set OD
IDNewValue = 0.72
ODNewValue = 1.6
Case "22"
'Set ID .640
'Set OD
IDNewValue = 0.64
ODNewValue = 1.4
Case "23"
'Set ID .570
'Set OD
IDNewValue = 0.57
ODNewValue = 1.3
Case "24"
'Set ID .510
'Set OD
IDNewValue = 0.51
ODNewValue = 1.2
Case Else
MsgBox "Unsupported AWG Size"
End Select
'For Metric Selection
Case "2"
WireSize = swCustProp.Get("Size_Metric")
Case "0.25"
'Set ID .564
'Set OD
IDNewValue = 0.564
ODNewValue = 1.5
Case "0.35"
'Set ID .668
'Set OD
IDNewValue = 0.668
ODNewValue = 1.7
Case "0.5"
'Set ID .798
'Set OD
IDNewValue = 0.798
ODNewValue = 1.9
Case "0.75"
'Set ID .977
'Set OD
IDNewValue = 0.977
ODNewValue = 2.1
Case "1"
'Set ID 1.128
'Set OD
IDNewValue = 1.128
ODNewValue = 2.3
Case "1.25"
'Set ID 1.262
'Set OD
IDNewValue = 1.262
ODNewValue = 2.5
Case "1.5"
'Set ID 1.382
'Set OD
IDNewValue = 1.382
ODNewValue = 2.7
Case "1.75"
'Set ID 1.493
'Set OD
IDNewValue = 1.493
ODNewValue = 2.9
Case "2"
'Set ID 1.596
'Set OD
IDNewValue = 1.596
ODNewValue = 3.1
Case "2.25"
'Set ID 1.693
'Set OD
IDNewValue = 1.693
ODNewValue = 3.3
Case "2.5"
'Set ID 1.784
'Set OD
IDNewValue = 1.784
ODNewValue = 3.5
Case "2.75"
'Set ID 1.871
'Set OD
IDNewValue = 1.871
ODNewValue = 3.7
Case "3"
'Set ID 1.954
'Set OD
IDNewValue = 1.954
ODNewValue = 3.8
Case "3.25"
'Set ID 2.034
'Set OD
IDNewValue = 2.034
ODNewValue = 4
Case "3.5"
'Set ID 2.111
'Set OD
IDNewValue = 2.111
ODNewValue = 4
Case "3.75"
'Set ID 2.185
'Set OD
IDNewValue = 2.185
ODNewValue = 4
Case "4"
'Set ID 2.257
'Set OD
IDNewValue = 2.257
ODNewValue = 4.25
Case Else
MsgBox "Unsupported Metric Size"
End Select
End Select
'Set Wire Color based on user selection
Select Case BaseColor
Case "Red"
BaseColor = AppearanceFolder + "Wire Red.p2m"
Call SetWireColor(BaseColor)
Case "Green"
BaseColor = AppearanceFolder + "Wire Green.p2m"
Case "Dark Green"
BaseColor = AppearanceFolder + "Wire Dark Green.p2m"
Case "Blue"
BaseColor = AppearanceFolder + "Wire Blue.p2m"
Case "Dark Blue"
BaseColor = AppearanceFolder + "Wire Dark Blue.p2m"
Case "Violet"
BaseColor = AppearanceFolder + "Wire Violet.p2m"
Case "Purple"
BaseColor = AppearanceFolder + "Wire Purple.p2m"
Case "Dark Purple"
BaseColor = AppearanceFolder + "Wire Dark Purple.p2m"
Case "Yellow"
BaseColor = AppearanceFolder + "Wire Yellow.p2m"
Case "Orange"
BaseColor = AppearanceFolder + "Wire Orange.p2m"
Case "Brown"
BaseColor = AppearanceFolder + "Wire Brown.p2m"
Case "Gray"
BaseColor = AppearanceFolder + "Wire Gray.p2m"
Case "Dark Gray"
BaseColor = AppearanceFolder + "Wire Dark Gray.p2m"
Case "Black"
BaseColor = AppearanceFolder + "Wire Black.p2m"
Case Else
MsgBox "Specified base color not yet supported"
End Select
'Rebuild
swModel.ForceRebuild3 True
'Function that colors the wire according to user selections in "Wire_Color" custom property
Function SetWireColor(AppearanceDirectory As String)
'Declare Variables
Dim nDecalIDColor As Long
Dim PrimaryColor As SldWorks.RenderMaterial
Dim ColorBoolStatus As Boolean
'Set Variables
Set PrimaryColor = swModelDocExt.CreateRenderMaterial(AppearanceDirectory)
'Clear current model color & apply new colors
swModel.ClearSelection2 True
ColorBoolStatus = PrimaryColor.AddEntity(swModel)
ColorBoolStatus = swModelDocExt.AddRenderMaterial(PrimaryColor, nDecalIDColor)
End Function
'Function that gets the index number of a specified global variable in the equation manager (sourced from https://www.codestack.net/solidworks-api/document/change-global-variable-value/)
Function GetEquationIndexByName(swEquationMgr As SldWorks.EquationMgr, name As String) As Integer
Dim i As Integer
Dim eqName As String
GetEquationIndexByName = -1
For i = 0 To swEquationMgr.GetCount - 1
eqName = Trim(Split(swEquationMgr.Equation(i), "=")(0))
eqName = Mid(eqName, 2, Len(eqName) - 2) 'removing the "" symbols from the name
If UCase(eqName) = UCase(name) Then
GetEquationIndexByName = i
Exit Function
Next
End Function
'Function that sets a specified global variable in the equation manager to a specified value (sourced from https://www.codestack.net/solidworks-api/document/change-global-variable-value/)
Function SetEquationValue(swEquationMgr As SldWorks.EquationMgr, name As String, value As Double)
Dim index As Integer
index = GetEquationIndexByName(swEquationMgr, name)
If index <> -1 Then
swEquationMgr.Equation(index) = """" & name & """=" & value
Else
MsgBox "Global variable not found"
End Function
Replace
With
You need to do a condition to run first line for parts and assemblies and second line when part is being edited in context of the assembly. To test this condition you can check if active doc is assembly and if so check if GetEditTarget is not nothing.
