How can I create a lot of similar components in a spreadsheet and import them into an integrated library file?
For example, in Pads, I can create a hundred 1/4W through-hole resistors in a spreadsheet by copying and pasting a single entry 100 times. Then edit the few changes to each entry, and then import the file into the Pads library and all the resistors are there.
How can something like this be done in SolidWorks PCB 2019?
robin
You can connect to a database or spreadsheet of part information using the dblink feature of 2018. I'm looking up a video as a light walk through to see if it would address your needs, but that is where I'd focus.
Review the info at the link:
http://documentation.solidworkspcb.com/display/SWPCB/NFS_((New+Database+Link))_PW
