Copy custom properties from parts and assemblies to drawings
Question asked by Nicholas Almond on May 9, 2019
Latest reply on May 10, 2019 by Christian Chu
We produce parts, assemblies and drawings for fabricators and rely heavily on custom properties. We export each drawing out as a PDF in the format: PART-NO.REVISION-LETTER.PDF. For example: SW001.issueA.PDF. This is saved and renamed manually despite the revision letter being in the custom properties.
When producing a new drawing for the part, the revision letter correctly pulls through to the drawing, but not to the custom properties. See below:
One solution was to use a macro to pull through the custom properties from the part to populate the drawing. This appeared to partially work but only on fields that were text (not drop-down menus) and only on parts. I'd need something to pull through custom properties from both parts and assemblies. Also, to pull through ALL of the fields. I stumbled across the below macro which only some way does what I need:
Option Explicit
Dim swmodel As SldWorks.ModelDoc2
Dim swmod As SldWorks.ModelDoc2
Dim swdraw As SldWorks.DrawingDoc
Dim swview As SldWorks.View
Dim v As Variant
Dim Propname As Variant
Dim evval As Variant
Dim model As String
Dim error As Long
Dim warning As Long
Dim config As Variant
Dim addstatus As Long
Dim i As Integer
Dim comp As SldWorks.Component2
Dim swCustPropMgr As SldWorks.CustomPropertyManager
Set swmodel = swApp.ActiveDoc
Set swdraw = swmodel
Set swview = swdraw.GetFirstView
Set swview = swview.GetNextView
v = swview.GetVisibleComponents
Set comp = v(0)
Set swmod = comp.GetModelDoc2
Propname = swmod.GetCustomInfoNames
Set swCustPropMgr = swmodel.Extension.CustomPropertyManager("")
For i = 0 To UBound(Propname)
evval = swmod.GetCustomInfoValue(config, Propname(i))
addstatus = swCustPropMgr.Add2(Propname(i), swCustomInfoText, evval)
evval = ""
Next
Question: Is there a way to link custom properties between parts & assemblies with their linked drawing, without needing a macro?
Secondary question: If not, could someone please point me in the right direction for accessing part and assembly custom properties?
Any help would be much appreciated!
