Simulation worker agent does not save results
Question asked by Libo Liang on May 9, 2019
Latest reply on May 14, 2019 by Libo Liang
When using the 2018 Simulation worker agent to remotely solve a flow simulation results are not being saved.
The calculation runs fine on the remote computer(s)
After it has finished the solver window shows the converged results and indicates that the calculation is finished. The batch run window indicates calculation ok, and all remaining simulations run without any errors.
But when trying to review the results it turns out that none of the results are saved.
When trying to load the results it indicates that there is no result file. Also in explorer no result files can be found, only automatically created reports that show the setup data but no results.
If the mesh was done first, separately from the calculation, a result can be loaded with only the mesh.
When running a simulation locally everything works fine.
A workaround for now is to make a screenshot of the solver window after the simulation is solved.
In this way we can at least record the main parameters.
We need the full result to be able to analyse the simulation results.
Does anybody have an idea of how to solve this?
