I have a parent drawing that many part numbers are represented on. (tabulated)
I want to check this into the PDM.
I want all the PNs on the parent drawing associated to the parent number
i.e.
P48-TAB-1234.sldprt
P48-TAB-1234.slddrw
P48-TAB-1234 Drawing number
P48-1234
P48-2345
P48-4567
All PN's above are represented on the drawing
When checking in the .slddrw I need the data card to have multiple tabs so each PN can be entered and stay associated. I only get multiple tabs on the data card when I check in the .sldprt.
How do I fix this? Is there some way I should be modeling so the .slddrw file upon checking it into the PDM
opens multiple tabs that I can then populate with each PN represented on the drawing?#CSI
