JHJosh Hixon07/05/2019
Okay, I have fought with this long enough, time to ask the genius of the forum community.
I have a macro that saves a drawing as a PDF into our PDM professional vault, problem is that it is grayed out because it is a local version. I can right click and add to the vault, but I would like for this macro to not only add it to the vault but to also check it in. I have poured over the PDM API help files and am still so lost. I find the way the help files code things very difficult to understand. My visual basic skill is growing but pretty beginner level still.
This is what I have but my very last line seems to be an issue I can't figure out what to do with it.
Dim Filepath As String
Dim FileName As String
Dim boolstatus As Boolean
Dim vault1 As New EdmVault5
Set swModel = swApp.ActiveDoc
' Check to see if a drawing file is loaded.
If (swModel Is Nothing) Or (swModel.GetType <> swDocDRAWING) Then
swApp.SendMsgToUser ("Only for use with Drawings")
Exit Sub
' vault login
vault1.LoginAuto "SPECTRUM", 0
' Set filepath and add tag on file name using custom properties
Set swDraw = swModel
Dim Rev As String
Dim folder As String
Rev = swModel.CustomInfo("Revision")
Filepath = "C:\SPECTRUM\Spectrum\Shop Pdf Access\"
If Right(Filepath, 1) <> "\" Then
Filepath = Filepath & "\"
FileName = Left(swDraw.GetTitle, Len(swDraw.GetTitle) - 10)
file = Filepath + FileName + " - " + Rev + ".PDF"
swDraw.SaveAs (file)
'add and checkin to vault
vault1.RootFolder.AddFile 0, Filepath, file, 0
