I am making similar parts. In one drawing, my bend line shows up solid, in another it shows as the correct chain-style.
How should I go about fixing this? What causes this hiccup?
Edit: Fixed Images
Check: Document Properties, Line Font.
Thank you, I did not realize the default was to have solid for upwards bend and hidden style for downwards bend. Was able to change it to have all bends as chain line style as per our company standard!
Have you looked in your feature manager under the flat pattern to see how the bend lines are set there?
