Hello all,
We have been playing around with an excellent macro from these forums >> Selecting a face and then clicking a macro button to create DXF
This has been modified to save to our particular saving location & drag specific custom properties to name the file from the sheetmetal part... all good there!
When exporting to DXF we need to map the file with bend line colours, so my thought was to modify the export code based on 2014 SOLIDWORKS API Help - swExportToDWG_e Enumeration :
"swExportToDWG_ExportSelectedFacesOrLoops" to "swExportToDWG_ExportSheetMetal" to enable to use of the DXF mapping tool
However when changed, the macro is producing no output.
Perhaps this was the wrong macro to start with? All help appreciated. Code below..
Option Explicit
' LATEST REVISION 06MAY2019 EDD - NOT SAVING AS SHEETMETAL
Sub Main()
Dim Part As SldWorks.ModelDoc2
Dim swFace As SldWorks.Face2
Dim swBody As SldWorks.Body2
Dim feat As SldWorks.Feature
Dim swCustPropMgr As SldWorks.CustomPropertyManager
Dim SelMgr As SldWorks.SelectionMgr
Dim BodyFolder As SldWorks.BodyFolder
Dim CutListBdy As Body2
Dim strValue(10) As String
Dim WorkFace As Face2
Dim WorkSurface As Surface
Dim savepathdxf As String
Dim varAlignment As Variant
Dim dataAlignment(11) As Double
Dim seltype As Integer
Dim i As Integer
Dim isThisAPlane As Boolean
Dim vBodies As Variant
Dim j As Integer
Dim wasResolved As Boolean
Dim itemnumber As Variant
Const SaveLoc As String = "R:\CUSTOMER BUILDS\- RECENT PDF FILES\RECENT FILES - EDD\TESTING\" 'Change Path here
Set Part = swApp.ActiveDoc
'Don't run if no part is loaded
If Part Is Nothing Then
swApp.SendMsgToUser "There is no part loaded."
GoTo cleanupandquitnopart
'did the user have the open file saved
If Part.GetPathName = "" Then
'user does not have open file saved
swApp.SendMsgToUser "Please save the file before running this script."
GoTo cleanupandquit
Set swCustPropMgr = Part.Extension.CustomPropertyManager("")
'Get Custom Property Project
swCustPropMgr.Get5 "Project", False, strValue(8), strValue(0), wasResolved
'Get Custom Property Number
swCustPropMgr.Get5 "Number", False, strValue(9), strValue(1), wasResolved
'did the user pre-select a face?
Set SelMgr = Part.SelectionManager
If SelMgr.GetSelectedObjectCount2(1) <> 1 Then
seltype = SelMgr.GetSelectedObjectType3(1, 0)
If seltype <> SwConst.swSelFACES Then
'user did not preselect one face
swApp.SendMsgToUser "Please select a (one) 2D face before running this command."
GoTo cleanupandquit
Else
Set swFace = SelMgr.GetSelectedObject6(1, -1)
Set swBody = swFace.GetBody
Set feat = Part.FirstFeature
While Not feat Is Nothing
If feat.GetTypeName = "CutListFolder" Or feat.GetTypeName = "SubWeldFolder" Then
Set BodyFolder = feat.GetSpecificFeature2
vBodies = BodyFolder.GetBodies
If Not IsEmpty(vBodies) Then
For j = LBound(vBodies) To UBound(vBodies)
Set CutListBdy = vBodies(j)
If CutListBdy.Name = swBody.Name Then
Set swCustPropMgr = feat.CustomPropertyManager
'Get Custom Property PART NO from cut list
swCustPropMgr.Get5 "PART NO", False, strValue(5), strValue(2), wasResolved
'Get Custom Property REV (REVISION) from cut list
swCustPropMgr.Get5 "REV", False, strValue(6), strValue(3), wasResolved
itemnumber = feat.Name
Next j
Set feat = feat.GetNextFeature()
Wend
'Determine if the selected face is a true 2D plane... exit if not
isThisAPlane = False 'initalize variable to false
'make sure that what is selected is a face... exit if not
If SelMgr.GetSelectedObjectType3(1, -1) <> 2 Then
swApp.SendMsgToUser "Item selected is not a face. You must select a (one) complete 2D Face to export."
GoTo cleanupandquit
Set WorkFace = SelMgr.GetSelectedObject5(1)
Set WorkSurface = WorkFace.GetSurface
isThisAPlane = WorkSurface.IsPlane
If isThisAPlane = False Then
swApp.SendMsgToUser "The face selected is not 2D. Please select a (one) 2D face before running this command."
GoTo cleanupandquit
'Save a DXF
dataAlignment(0) = 0#
dataAlignment(1) = 0#
dataAlignment(2) = 0#
dataAlignment(3) = 1#
dataAlignment(4) = 0#
dataAlignment(5) = 0#
dataAlignment(6) = 0#
dataAlignment(7) = 1#
dataAlignment(8) = 0#
dataAlignment(9) = 0#
dataAlignment(10) = 0#
dataAlignment(11) = 1#
varAlignment = dataAlignment
'Clean off the file name so that we can add our desired name
'savepathdxf = SaveLoc
'### previous code = 'Left(Part.GetPathName, InStrRev(Part.GetPathName, "\"))
'File name in the standard of PART NO & REV & .DXF
savepathdxf = SaveLoc & strValue(5) & " " & strValue(6) & ".DXF"
'Export selected face to a DXF
Part.ExportToDWG2 savepathdxf, Part.GetPathName, swExportToDWG_ExportSelectedFacesOrLoops, True, varAlignment, False, False, 101, Null
Part.ClearSelection2 False
GoTo cleanupandquit
'DRAWING (this macro started while a drawing was active )
GoTo cleanupandquit
cleanupandquit:
Part.DeleteConfiguration (Part.GetActiveConfiguration.Name & "SM-FLAT-PATTERN")
Set swApp = Nothing
Set Part = Nothing
Set SelMgr = Nothing
cleanupandquitnopart: 'only called if no part is loaded
Set swApp = Nothing
Set Part = Nothing
It works fine here. The only thing I changed is the directory. I didn't even need the custom properties in my part, so the file was named "[space].DXF"
I would suggest you do the following though:
Before I started I though the orientation of X and Y might be the issue, but I could select any plane in my weldment and the export would go correctly.
