separate the custom properties mapped in multiple-sheet drawing
Question asked by Prich Ngamsirikulchai on May 3, 2019
If my drawing has 10 sheets, the first sheet is my assembly and the others are my parts used in the assembly.  I've mapped the custom properties in my drawing sheet format which shown the part "revision" in its sheet.
The question is if my part has been updated the revision by workflow transition in SW PDM, Is the entire sheet would be updated or only the sheet that i have updated the part revision. If I would like to do that, what should i do?
in the same way  if i've mapped the "approved by" in PDM (i've already made the "set variable" action) with the drawing sheet format, Is the entire sheet also updated the custom property or only the sheet of the part that has been approved.
Thank you in advanced
