Hello everyone,
I'm fairly a beginner in solidworks, so please bear with me.
I'm going through the tutorial introsw.pdf and got to the point of making faucet handle.
I created a similar handle base sketch and used the revolve tool so now I have a solid body:
Thing is I saw in the bottom of the window that the document is under-defined, and thought it would be a good exercise to define it fully.
But when I try to change, per example, the base height - I cannot. it is grayed out.
I saw somewhere in my google search that I should just right-click it and change it to driving dimension, though it doesn't seem to appear in the menu:
How should I proceed?
Jordan.
P.S. I'm using SW2018 SP4, and can only find "smart dimension" tool in sketch menu.
You need to edit the sketch in order to add or edit dim's.
To do this locate the sketch in the design tree on the left hand side > RMB > Edit Sketch > The sketch lines will change colour to blue or black from here you can now add other dim's to fully define everything.
Adam
