I'm trying to set up a gauge table for our aluminum bending, but receive an error whenever I flatten the part. I have attached the gauge table being used as well as before/after pictures of the part showing the sheet metal feature setup as well as the flattened problem.
The error I'm receiving:
"The radius of this bend fell outside the bend allowance/deduction table. The bend allowance/deduction is evaluated using the K factor instead."
As is shown in the attachments, the bend radius in the excel sheet exactly matches the value shown when setting up the sheet metal feature. The Excel uses 2-digit precision for the bend radii.
I tried to follow the gauge table format shown on the SolidWorks help page.
Does anyone know what might be happening?
I'm having the same issue with trying to use the bend table for the bend deduction. When I manually type in the bend deduction, it works great, but when using the table, with the same value, it fails.
