some question about get context between subassembly and topassembly
Question asked by Lenny Yang on May 1, 2019
Latest reply on May 2, 2019 by Lenny Yang
hi everybody,
I have some question about get context between subassembly and topassembly use "GetCorresponding" or "GetCorrespondingEntity".
See the code and attachments。
'here is my vba code=====================================================
Option Explicit
    Dim swModelDocExt As SldWorks.ModelDocExtension
    Dim swAssComp As SldWorks.Component2
    Dim PreSelectType As Integer
    Dim swCompModel As SldWorks.ModelDoc2
    Dim nRetval As Long
    Dim vPIDarr As Variant
'Step1-Open "SubAssembly"
'Step2-Select component "A" or an Edge of "A"
'Step3-Run this macro
    Set swModel = swApp.ActiveDoc
    Dim SelType As swSelectType_e
    SelType = swSelMgr.GetSelectedObjectType2(1)
    'mark the selection type
    If SelType = swSelectType_e.swSelCOMPONENTS Then
        PreSelectType = 0
        Dim swSelComp As SldWorks.Component2
        Set swSelComp = swSelMgr.GetSelectedObject6(1, 0)
        Set swModelDocExt = swModel.Extension
        vPIDarr = swModelDocExt.GetPersistReference3(swSelComp)
    ElseIf SelType = swSelectType_e.swSelEDGES Then
        PreSelectType = 1
        Dim swSelEnt As SldWorks.Entity
        Set swSelEnt = swSelMgr.GetSelectedObject6(1, 0)
        vPIDarr = swModelDocExt.GetPersistReference3(swSelEnt)
Stop
'Step4-Close "SubAssembly"
'Step5-Open the "TopAssembly"
'Step6-Select the component "SubAssembly" in SubAssembly
'Step7-Press F5 to Continue this macro
    Set swAssComp = swSelMgr.GetSelectedObject6(1, 0)
    Set swCompModel = swAssComp.GetModelDoc
    Set swModelDocExt = swCompModel.Extension
    swModel.ClearSelection
    If PreSelectType = 0 Then 'if we select a component
        Dim compAInSubAss As SldWorks.Component2
        'Here we can Reacquire the component or edge which save in "vPIDarr".
        Set compAInSubAss = swModelDocExt.GetObjectByPersistReference3((vPIDarr), nRetval)
        Dim compAInTopAss As SldWorks.Component2
        Set compAInTopAss = swAssComp.GetCorresponding(compAInSubAss)
        Debug.Print compAInTopAss.Name2
        compAInTopAss.Select (False) '--------------------->can not select the compInTopAss successful.why????????
    ElseIf PreSelectType = 1 Then'if we select an edge
        Dim entityInSubAss As SldWorks.Entity
        Set entityInSubAss = swModelDocExt.GetObjectByPersistReference3((vPIDarr), nRetval)
        Dim entityInTopAss As SldWorks.Entity
        Set entityInTopAss = swAssComp.GetCorrespondingEntity(entityInSubAss) '-------------------------->here return nothing,why????????????????
        entityInTopAss.Select (False)
