BWBen Wollenburg29/04/2019
I am attempting to add styles to our drawing templates. I can add the styles and save them. When we use them, if we select the dimension then the correct style, the dimension will change. However, if we select the style then select the item to be dimensioned, it shows the correct style, then when you place the dimension, then click the green check mark, then style changes to the last style in the list.(or it changes to whatever you do not want). Why is this? Can you only have one style? Is there some default that is over-riding the style of our choice? Does the style need to be saved in a particular location/path?
