How can i transform a Temporary body twice or more
Question asked by Lenny Yang on Apr 28, 2019
Latest reply on May 2, 2019 by Lenny Yang
hello every body,
I can transform a Temporary body at the first time when i use "IBody2 Interface : ApplyTransform Method (IBody2)".but i can't transform more than twice.
I know that I can copy again when i want to transform it at the second time,But this is too inefficient.
here is the code:==========================================================
' Preconditions:
' Just open a assembly and select a single body part.
Option Explicit
    Dim Body As SldWorks.Body2
    Dim BodyCopy As SldWorks.Body2
    Dim status As Boolean
    Dim Component As SldWorks.Component2
    Dim MathUtility As SldWorks.MathUtility
    Dim MathXform1 As SldWorks.MathTransform
    Dim Xform1(15) As Double
    Dim vXform1 As Variant
    Xform1(0) = 0#
    Xform1(1) = 1#
    Xform1(2) = 0#
    Xform1(3) = 0#
    Xform1(4) = 0#
    Xform1(5) = 1#
    Xform1(6) = 1#
    Xform1(7) = 0#
    Xform1(8) = 0#
    Xform1(9) = 0.15
    Xform1(10) = 0#
    Xform1(11) = 0#
    Xform1(12) = 1#
    Xform1(13) = 0#
    Xform1(14) = 0#
    Xform1(15) = 0#
    vXform1 = Xform1
    Dim MathXform2 As SldWorks.MathTransform
    Dim Xform2(15) As Double
    Dim vXform2 As Variant
    Xform2(0) = 1#
    Xform2(1) = 0#
    Xform2(2) = 0#
    Xform2(3) = 0#
    Xform2(4) = 1#
    Xform2(5) = 0#
    Xform2(6) = 0#
    Xform2(7) = 0#
    Xform2(8) = 1#
    Xform2(9) = 0.15
    Xform2(10) = 0#
    Xform2(11) = 0#
    Xform2(12) = 1#
    Xform2(13) = 0#
    Xform2(14) = 0#
    Xform2(15) = 0#
    vXform2 = Xform2
    Dim retval As Long
    Dim fileName As String
    Dim errors As Long
    Dim warnings As Long
    Set MathUtility = swApp.GetMathUtility
    Set MathXform1 = MathUtility.CreateTransform(vXform1)
    Set MathXform2 = MathUtility.CreateTransform(vXform2)
    Set swModel = swApp.ActiveDoc
    Set Component = swSelMgr.GetSelectedObjectsComponent4(1, -1)
    Set Body = Component.GetBody
    Set BodyCopy = Body.Copy
    BodyCopy.ApplyTransform MathXform1
    'Display temporary body
    retval = BodyCopy.Display3(Component, 255, swTempBodySelectable)
    Debug.Print "Temporary body displayed (0 = success)? " & retval
    'Here transform the Temporary second time use "ApplyTransform" function.But it does not work
    BodyCopy.ApplyTransform MathXform2
    retval = BodyCopy.Display3(Component, 100, swTempBodySelectable)
    swModel.ViewZoomtofit2
