I am running a nonlinear static simulation by SolidWorks and keep receiving the warning message in the solver window: "PCGLSS0085:writeSparseFactor:valueVec tried to IO 27 bytes". Then the simulation will be terminated because of the lack of adequate fixtures, improper material properties or improper load increments. But I am positive that these constraints and properties are correct. I couldn't find any explanations for the warning message online. Have you seen the same warning before and know what it means?
I attach the warning messages for reference.
I appreciate any ideas or suggestions from you!
Hi
I could be wrong but maybe try using a different solver, seems the error has something to do with the solver type.
I'll suggest to use the intel direct sparse solver or large probleme direct sparse.
You get this by right clicking on your study and selecting properties.
see if you get the same error, but you will most probably still get the error regarding the lack of adequate fixtures, improper material properties or improper load increments, try decreasing your time increment under you options as well.
Hope this helps.
Regards
RVDB
