How about using either “Add Loft Section” in drop down menu or adding a profile manually. Which one is most preferred? Because I found “Add Loft Section” is less controllable.
I found that “Add Loft Section” profile is less manipulative compared with profile created (sketched) manually. I wish to know whether it is advisable to use it.
well... It's a tool to modify feature so you don't have to start over
Question is: you don't like the feature and want to learn about it?
