Hi Guys
i have a 3D file (STEP) that is downloaded from a manufacturers website......opens fine and all is good, can even save it no problem as a SW part
My problem comes when i have used the above file in a SW assembly and i go to SAVE AS (all referenced components) to a new directory - i then get an error message which says
"File name entered was invalid, not found, locked or of an incompatible type"
I cant seem to find a way around this.......can any one advise??
STEP file attached
Adrian
I downloaded your file and attempted to recreate your error but could not. Everything worked just fine.
Perhaps your file name string is too long. There is a limit to the Windows directory string + component name (256 characters?). If that's the case, try saving local and see if it works.
Solidworks Premium 2019 SP1.0
Windows 10 Pro
Intel Xeon CPU E5-2667 v4 @3.20GHz
64 GB Ram
Nvidia Quadro M5000
