Customizing the PDM convert task so that it only runs in certain circumstances
Question asked by Elisabeth Daley on Apr 25, 2019
Latest reply on May 1, 2019 by Elisabeth Daley
Can anyone help me how to get this customized PDM convert task to return a 'Success' status?  I've edited it so that the main sub reads:
       On Error GoTo Fail :
    Set FileSystemObj = CreateObject("Scripting.FileSystemObject")
    docFileName = "<Filepath>"
    Dim convertRequested
    convertRequested = 0
    If (convertRequested = 1) Then
   ' Get SW interface object
    swApp.Visible = True
        Convert docFileName
    Else
        Success = True  ' this isn't actually doing anything, trying to figure out how to replace it with something that will cause the task to complete without a failed status
Exit Sub
Fail:
    Log "Error while converting file '" & docFileName & "': " & vbCrLf & _
    "An unexpected error occurred while executing the generated script. Script syntax error?" & vbCrLf & _
    "Error number: " & Err.Number & vbCrLf & _
    "Error description: '" & Err.Description & "'" & vbCrLf
In my real application, I'll replace the 'convertRequested = 0' line with some logic, but when I run this simple code, the task fails with a 'no file converted' error.  Which is true, nothing is converted, but that's the correct behavior in this case.  Does anyone know how to change this?
