Macro Help: Sheetmetal Export (DXF), arrange by thickness
Question asked by Desenhos 01 Schemaq on Apr 24, 2019
Latest reply on Apr 25, 2019 by Fifi Riri
Hi guys. First time working with macros on Solid.
My problem is the following:
I have to update sheet metal parts when they are changed. I have to save the part as dxf (or export), Change the folder to the respective thickness, and that´s all.
I have a macro working, but it dont separate by the thickness of the part.
What i need is, this exact same macro, but when exporting the DXF, i saves on the folder named by the thickness (or material).
        Set swModel = swApp.ActiveDoc
        'swModel.Save
        Path = "D:\Engenharia\Desktop\Temp\Sheetmetal" ' Change the path here
        sModelName = swModel.GetPathName
        If sModelName = "" Then
            MsgBox "File is not Saved Yet. You have to Save the file First."
            End
        sPathName = Mid(swModel.GetPathName, InStrRev(swModel.GetPathName, "\") + 1)
        sPathName = Left(sPathName, InStrRev(sPathName, ".") - 1)
        'sPathName = Path + sPathName + ".DXF"
        sPathName = Path + "\1.DXF"
        Set swPart = swModel
        dataAlignment(0) = 0#
        dataAlignment(1) = 0#
        dataAlignment(2) = 0#
        dataAlignment(3) = 0#
        dataAlignment(4) = 0#
        dataAlignment(5) = 0#
        dataAlignment(6) = 0#
        dataAlignment(7) = 0#
        dataAlignment(8) = 0#
        dataAlignment(9) = 0#
        dataAlignment(10) = 0#
        dataAlignment(11) = 0#
        varAlignment = dataAlignment
'       The bitmask for SheetMetalOptions is {12 11 10 9 8 7 6 5 4 3 2 1}, where each bit is either 0 or 1 as follows:
'       https://forum.solidworks.com/thread/93981
'       Bit #1: 1 to export flat-pattern geometry; 0 to not
'       Bit #2: 1 to include hidden edges; 0 to not
'       Bit #3: 1 to export bend lines; 0 to not
'       Bit #4: 1 to include sketches; 0 to not
'       Bit #5: 1 to merge coplanar faces; 0 to not
'       Bit #6: 1 to export library features; 0 to not
'       Bit #7: 1 to export forming tools; 0 to not
'       Bit #8: 0
'       Bit #9: 0
'       Bit #10: 0
'       Bit #11: 0
'       Bit #12: 1 to export bounding box; 0 to not
'       For example, if you want to export:
'       flat-pattern geometry, bend lines, and features, then Bits 1, 3, and 6 are 1, the bitmask is :
'       Fill th binary from right starting with 0 column
'       11  10  9  8   7    6          5           4          3          2          1          0     -> Binary Nomber column, filling from right
'         0    0  0  0   1    0          1           0          0          1          0          1     -> 000000001101
'                          2^7           2^5                               2^2                  2^0
'       and you need to set SheetMetalOptions = (2^0) + (2^2) + (2^5) + (2^7) = 1 + 4 + 32 + 128= 165
        options = 101 ' This value determines what would be exported in the DXF/DWG file.
        swPart.ExportToDWG2 sPathName, sModelName, swExportToDWG_ExportSheetMetal, True, varAlignment, False, False, options, Null
