We recently implemented PDM and I'm rolling with the changes. In summary, I am hoping to use the Dispatch add-in to help with our process. I would like dispatch to check out the PDF associated with a SLDDRW file when the SLDDRW file is checked out. We'd make any changes, save the PDF and then check the SLDDRW back in and I would like Dispatch to then check the PDF back in as well.
This would save a ton of time navigating windows explorer to find the file and check it in and out.
OR
Is it possible to include the PDF in the "check in/out" prompt that opens when opening solidworks files for editing. I'm not sure if I have a broken reference, or if PDM was never designed to include PDF files as referenced files since they aren't native to solidworks.
Please advise.
Thanks!
I am pretty sure the PDF should show the drawing on the Contains tab.
The drawing should show the PDFs on the Where Used tab.
Automatic check out of the PDFs would be applied according to the user/group setting.
Without the setting applied:
the checkout box is empty.
With it applied:
The files are selected for check out.
The downside is that all the reference files are then checked out.
I think a dispatch would act the same way and checkout/in all the related files.
