Whenever I try to run import or export tasks in task scheduler, I get a similar output to below. I can open the file from solidworks and everything works fine, so it's not an issue with the step file. How can I solve this or debug it further?
Example output:
General Information |
Task Title: | Subtask 1 of 1 - import file [REV-21-1650.STEP] | |
Task Type: | Import STEP file | |
Task File Path: | C:\Users\*****\Documents\robot\library\motors\steps\REV-21-1650.STEP | |
Application Path: | C:\Program Files\SOLIDWORKS Corp\SOLIDWORKS\sldworks.exe | |
Scheduled Time: | 04/22/2019 09:09:50 | |
Actual Start Time: | 04/22/2019 09:56:09 | |
Finish Time: | 04/22/2019 09:56:51 | |
Task Status: | Failed unexpectedly | |
Comments: | Error! No SOLIDWORKS file was created. |
turn off PDM (in your add-ins) before you run it. see if that helps.
