Hi all,
anyone know how to coincident the segment points to fit spline so when i change the dimension the points change too? My sketch has lines and arcs and i want to use sketch segment to get equal distance points on all the sketch not just on 1 line or 1 arc so i use fit spline to join them but when i use segment on fit spline they don't attach to it(when i change the dimension of the sketch, the fit spline change with them but not the points). Thanks in advance
1st pic: i use fit spline
2nd pic: i use segment on fit spline
3rd pic: some points dont attach to the spline
EDITED BY MODERATOR: Moved to the Sketching space. Please post in the appropriate space when one exists.
Hi An
This looks like a bug to me... or at least an enhancement request.
I'm sure there will be several work-a-rounds,,, here is one that came to mind
Would a circle serve your purpose in lieu of a point? (they are equivalent)
Here I used a curve driven pattern of circular planar surfaces.
There is no need to use a fit spline as the curve driven pattern can take your original sketch as input
You can easily update the pattern instances and driving sketch
You can use concentricity to find the center point
If you don't mind me asking - for what purpose do you require the segments/points?
If you could give more information regarding the desired outcome there very well be a much better way.
