Getting this error when try to add "Convert_gb.cex" for PDM standard! The message pop-up just on clicking on the add-ins section. Anyone had same problem and how to solve that?
a far as i know, there is no support for conversion tasks in PDM Standard!
Just a plain PDF conversion is possible.
Because PDM Standard is a "stripped" version of PDM Professional, there might be some files and folders visible, wich are not functional (but intended).
You'll find the comparison here: SOLIDWORKS PDM | SOLIDWORKS
Heiko,
I know its a simple version of convert however I cant get it to work. Even the SWTaskAddin I am not able to add!
https://www.javelin-tech.com/blog/2018/05/solidworks-pdm-pdf-convert-task/
Which PDM Standard version you have? I remember (I may be wrong) that this option came to 2018 version.
Second is your user rights (Administrative right / Update task settings). Try to use "admin" account if adding right wont help.
Solved! The user admin in pdm administrative tool was corrupt. Created a second vault and copied that admin user over. After that it worked like normally.
