Let's say I want to do a linear feature pattern- I choose the direction, easy.
If I want to make a pattern of the same feature in the opposite directions, as far as I can tell, I have to either:
1) Choose a different edge/axis/plane than the one used to define direction 1
2) Use the same edge/axis/plane, but in a separate feature
It seems ridiculous to me that you can't choose the same feature to define both directions within one linear pattern.
EDITED BY MODERATOR: Moved to Parts and Features space. Please post to the appropriate space when one exists. About the Forums is for posts specifically about the SOLIDWORKS forum itself, not the SOLIDWORKS software.
I can select the same:
This is SW2018, which version are you using?
It may also be selected entity type dependent. What are you selecting?
Kevin
