I need a workflow transition to test for a missing variable and a missing value.
I've created workflow to set the rev level of documents based on the revision table in the drawing. This checks for the revision property.
How do I process files that do not have a revision custom property or files where the property is blank?
I could put custom property in our template but files that come from other sources might not have it and would get stuck in the workflow.
I've created a macro that can check and set the properties but users don't always run it.
In order for PDM to create custom properties they need to be on the data card applicable to the folder the file is checked into. The data card could also file in a blank property to a default setting or maybe one from a list or something.
