Trying to install PDM Server (2018 SP3). SQL and PDM are installed on separate virtual servers. Running on Windows Server 2016. A new SQL admin account has been created by IT for running PDM on the SQL server. When installing PDM server I get the following error:
Error 27502. Could not connect to Microsoft SQL Server "ServerName". [DBNETLIB][ConnectionOpen (SECDoClientHandshake()).] SSL Security error. (18)
I was suggest the starting point to be to make sure you can ping and telnet between the servers. When you telnet test it to the SQL server on port 1433. When testing from the SQL server to the Archive server test it on 3030.
Did you install the SWPDM data server application on the SQL server?
If Windows firewall is running on the servers you will need to open the ports for the application to get in and out.
