Generate terminal strip with pin "name"?
Question asked by Facecontrol Automacao on Apr 17, 2019
Latest reply on Apr 17, 2019 by Evan Stanek
Hi. I generate a terminal strip, as you can see in annex 3, but the information described there in I write manually because the terminal strip appears only from which component comes.
I would like to know if you have automated and appear the name of the pin and the name of the component?
An example. In Annex 2, terminal 2 comes from the 4F1 + pin power supply, then on the terminal strip I had to write: + Source 4F1 (according to Annex 3). I wanted to know if I can generate this script automatically when I generate the drawing of the terminal strip, maybe adding the name of the terminals (according to Annex 2) or some other way?
Another example is a PLC, I wanted the terminal strip to consist of exactly which PLC pin comes / goes out the terminal.
I've tried several things, but I still can not. Can you help me?
Thank you.
