Hey everyone,
I'm trying to make a complex transparent section view in Visualize. I have the basic idea down (See image below), but since I have the parts overlapping, the appearance doesn't look perfect (notice the "glitchiness").
I have the sectioned part ("FINAL ASSEMBLY2") overlapping the unsectioned part "FINAL ASSEMBLY") at the moment. Then I made the unsectioned parts
lower in opacity:
Let me know if there is a better way to do this.
Jake
Jeff, thank you for your help, you were completely right. Here is some instruction I received from one of my friends, fleshing out everyone's advice:
Overlapping components within Visualize can indeed cause these artifacts. It is preferred in this case to section the assembly using the Split feature on a part level environment. I found that the easiest way to go about it is as follows:
The suggested workaround is to slightly scale one of the bodies that share that contact within the SOLIDWORKS model before importing it into Visualize.
