I tried using a parallel approval in a new workflow since it's exactly what we need, but I noticed that no notifications are sent until after all parties have approved. Am I setting something up incorrectly or is this a flaw in parallel approvals?
I also tried setting the "Send Email" action, but that also does not trigger until after all parties approve.
Should I give up on parallel approvals? Or is there a way to hook into them with the API? I imagine the "EdmCmdType.EdmCmd_PreState" command would run into the same issue.
For reference, I'm using PDM Professional 2018 SP4
Thank you,
Tara
Hi Tara
The required information is stored in the TransitionParallelStates table. You can check this table for changes and, if necessary, inform the relevant persons.
BiI SAP-PDM
