Ok so i modeled a part in SW2019 in inches but thought I was in MM. The dimensions reflect the mm sizes so when I change units, the dimensions change to the mm value and part is way too big. Is there a way to preserve the original dimension numbers in SW. I used to be able to do this in Inventor by specifying to keep dimension numbers intact. Anything like that in SW?
Nope. You can try the Model Rescaler macro by Leonard Kikstra here:
Lenny's SolidWorks Resources
