What would make this value unlinkable?
I am trying to link a linear dimension to another linear dimension, but SW says "Incompatible range of values make the dimensions unlinkable." yet the values are both 12.250".
Hello Sarah,
I'm a big believer in using relations instead of dimensions whenever practical, and I especially prefer using relations instead of equations. Instead of the linked dimension, I'd recommend deleting the 2.000 dimension and making a coincident relation between the line and point indicated below. Unless I misunderstand what you're trying to do that will accomplish the same thing.
This was 100% an example sketch. In the actual model the dimensions are in separate sketches on different planes, which is why I was using linked values.
Sarah Dwight - Within the same model you can easily link using the = key in the dimension dialog box.
I appreciate the alternate solutions to the problem, but that does not answer my original question as to why the values would be unlinkable. I know now that it must have something to do with the mirrored slot shape, but still no reason why the "Incompatible range of values make the dimensions unlinkable."
To link two dims try to use equation
