ExportToDWG2 Crashes solidworks
Question asked by Miguel Goncalves on Apr 8, 2019
Latest reply on Apr 8, 2019 by Miguel Goncalves
I don't know what I'm doing wrong in this macro, but it does export a dwg but also crashes solidworks.
I was trying to replicate a problem with a larger macro that needs to be run twice to export the flat pattern of sheetmetal (first exports a empty dwg and in the second run export the flatpattern)
'Option Explicit
Dim swApp                   As SldWorks.SldWorks
Dim swModel                 As SldWorks.ModelDoc2
Dim varAlignment As Variant
Dim dataAlignment(11) As Double
'Set swApp = CreateObject("SldWorks.Application")
Set swModel = swApp.ActiveDoc
If swModel Is Nothing Then
    swApp.SendMsgToUser2 "A part needs to be open", swMbWarning, swMbOk
    Exit Sub
dataAlignment(0) = 0#
dataAlignment(1) = 0#
dataAlignment(2) = 0#
dataAlignment(3) = 0#
dataAlignment(4) = 0#
dataAlignment(5) = 0#
dataAlignment(6) = 0#
dataAlignment(7) = 0#
dataAlignment(8) = 0#
dataAlignment(9) = 0#
dataAlignment(10) = 0#
dataAlignment(11) = 0#
varAlignment = dataAlignment
Dim shetoptions As Long
shetoptions = 1   'include flat-pattern geometry
Dim modelType As Long
modelType = swModel.GetType
If modelType = swconst.swDocPART Then
        Dim RootPath As String: RootPath = Left(swModel.GetPathName, InStrRev(swModel.GetPathName, "\"))
        Dim result As Boolean
        result = swModel.ExportToDWG2(RootPath & "FlatTest.dwg", swModel.GetPathName, 1, True, varAlignment, False, False, shetoptions, Nothing)
Else
    swApp.SendMsgToUser2 "Is not a part file.", swMbWarning, swMbOk
Exit Sub
Thanks in advance!
