Hi all,
I have a really quick question and feel a bit stupid asking it. Is it possible at all to extrude cut between two sketches? Attached is a photo of one of my parts and I need to create a divot in the top surface to connect it to another part. The part I'm connecting it to has an extruded solid and I'm trying to connect them also like legos and gluing them together after printing.
Brandon
I figure it out after a lot of frustration. I created a boundary from the two sketches, extruded boundaries, and surface offset the original boundary to create the ring I wanted. I then stitched them together and subtracted it from the solid body of my model. I found out that I didn't select solid bodies during my macros for each segment when I was making the outer wall, and had to go back and fix all of the segments in my model. Thanks for the help though! Hopefully this information may help others in the future. (I attached an image of one example I just finished)
