Hi. Every file I use, with the overall units set to .00 decimal places, for some reason in sketches I get 0.000000 . How do I stop the 6 decimal places?
First, are those dimensions set to 'document'? If they are not, they will not use the overall setting, and you will have to change each dimension manually. Should be able to do that by selecting all the dimensions and making the change to all of them.
Second. Are you talking about a drawing or a part? If you set the 'drawing' to .00, it will only affect the drawing, not the part/assembly/component. And vice versa for the component.
