GLGian Luca Taroni07/04/2019
Hallo,
I'm working on a fresh environment with visual studio 2019 (free edition) and solidworks 2018 (installed on same machine).
I start from the beginning….but is not working and also all the example attached on documentation are non working.
I started a new project > vb.net console application
Added reference to Solidworks.Interop.sldworks and Solidworks.Interop.swconst
And this is my code
Imports SolidWorks.Interop.sldworks
Imports SolidWorks.Interop.swconst
Module Module1
Dim swPart As PartDoc
Dim swModel As ModelDoc2
Dim swModelDocExt As ModelDocExtension
Dim swImportStepData As ImportStepData
Dim status As Boolean
Dim errors As Integer
Dim warnings As Integer
Dim fileName As String
Dim stepFileName As String
Dim swApp As SldWorks = CreateObject("SolidWorks.Application")
'Open the SOLIDWORKS part document to export to a STEP file
fileName = "C:\Program Files\SOLIDWORKS Corp\SOLIDWORKS\Toolbox\data\SteelLib\channel.sldprt"
swPart = swApp.OpenDoc6(fileName, swDocumentTypes_e.swDocPART, swOpenDocOptions_e.swOpenDocOptions_Silent, "", errors, warnings)
swModel = swPart
swModelDocExt = swModel.Extension
'Export the SOLIDWORKS part document to a STEP file
stepFileName = "C:\Users\Luca\Desktop\api\db9 male.STEP"
status = swModelDocExt.SaveAs(stepFileName, 0, swSaveAsOptions_e.swSaveAsOptions_Silent, Nothing, errors, warnings)
swPart = Nothing
swApp.CloseDoc("db9 male.sldprt")
'Get import information
swImportStepData = swApp.GetImportFileData(stepFileName)
'If ImportStepData::MapConfigurationData is not set, then default to
'the environment setting swImportStepConfigData; otherwise, override
'swImportStepConfigData with ImportStepData::MapConfigurationData
swImportStepData.MapConfigurationData = True
'Import the STEP file
swPart = swApp.LoadFile4(stepFileName, "r", swImportStepData, errors)
swModel = swPart
'Run diagnostics on the STEP file and repair any bad faces
errors = swPart.ImportDiagnosis(True, False, True, 0)
End Module
When I try to run I get the following error:
System.Exception
HResult=0x80131500
Message=Cannot create ActiveX component.
Source=Microsoft.VisualBasic
StackTrace:
at Microsoft.VisualBasic.Interaction.CreateObject(String ProgId, String ServerName)
at ConsoleApp1.Module1.main() in C:\Users\Luca\Documents\Visual Studio 2019\Project\ConsoleApp1\ConsoleApp1\Module1.vb:line 19
on line highlighted in bold.
I did not find any fresh code on solidworks example.
