I am having an issue with a drawing dimension coming in at an angle to the part rather than at 90 degrees on the side like normal. I have tried using the center marks as well as the hole and slot surfaces. I have even placed a point at the center of the slot side and attempted to use it with no success. I have used the measure tool and everything is showing parallel or perpendicular so that does not appear to be the problem. Does anyone have any suggestions? SW 2018 SP4.
set the dimension type to projected instead of true.
