Templates added to vault not showing up in Addin search
Question asked by Chris Novak on Apr 4, 2019
Latest reply on Apr 4, 2019 by Chris Novak
I've run into a problem I'm rather baffled about. I have added a few templates to my vault via the PDM administration application. They are definitely there and in the list of all the other templates. I also have an addin that loops through the templates using IEdmTemplateMgr5. (VB Code below) But in the code, when looping through the templates, the newly added templates do not show up in the list at all (confirmed by the MsgBox call below. I never see the new templates from the add in, but they are definately in the vault). What am I not understanding here?
Private Sub CreateNewDocument(poCmd As EdmLib.EdmCmd, vault As EdmVault5)
        Try
            'Open a form to select a document template
            Dim myForm As New frmNewDocumentForm
            myForm.ShowDialog()
            If myForm.strDocumentType = vbNullString Then Exit Sub
            'Concatenate the template name string based on the form
            Dim templateName As String
            If myForm.strDocumentType = "Other" Then
                Cursor.Current = Cursors.Default
                Call CreateOtherDocument(poCmd, vault, myForm.strProcessType)
                Exit Sub
            Else
                templateName = "QMS Document\" & myForm.strDocumentType & "\" & myForm.strProcessType
            Cursor.Current = Cursors.WaitCursor
            'Open the template manager
            Dim templateMgr As IEdmTemplateMgr5
            Dim template As IEdmTemplate5
            Dim pos As IEdmPos5
            templateMgr = vault.CreateUtility(EdmUtility.EdmUtil_TemplateMgr)
            pos = templateMgr.GetFirstTemplatePosition
            Dim boolTemplateFound As Boolean = False
            'Loop through all the templates until we find the one
            While Not pos.IsNull
                template = templateMgr.GetNextTemplate(pos)
                Call MsgBox("Name: " & templateName & "\rName: " & template.GetMenuString)
                If template.GetMenuString = templateName Then
                    'Run the template
                    template.Run(poCmd.mlParentWnd, vault.RootFolderID)
                    boolTemplateFound = True
                    Exit While
            End While
