Ok. I am making a stand from 2x3 rectangle tubing with angle iron. The RT2x3x.25 is being used for the supports/legs, while the angle is the frame, more less. Each of the four legs is splayed. I am trying to create a drawing from the part. I have a cut list wits “Angle 1“ and “Angle 2”, but I would like to display the angles/cuts for each particular leg. I am able to add the body to a separate page and rotate it, but cannot change the view to a “normal too” in a face.
Can someone help me or explain how to isolate a leg, add it to a drawing, normal too a face, and add cut angles to the part? I would like to had the drawings to the shop and they take the piece of steel, cut, and weld.
All four legs are splayed like the two front legs of a windsor chair.... if it helps.
Hi
In your drawing select a view then go Insert - Drawing View - Relative to Model. your 3D model should open up with this box. select the selected body option then pick the part required and set your faces or planes (Front, back etc) this view then comes in to your drawing
thanks
Mark
