If saving the file (file menu "save") then it will appear nothing
happens.
If you're saving an image you need to render to the render window
first and then select save image. A save dialog box will open
allowing to set your options and save the file.
You can also just save a screen shot render using the menu (can't
remember which actual menu item it's listed under).
If saving the file (file menu "save") then it will appear nothing happens.
If you're saving an image you need to render to the render window first and then select save image. A save dialog box will open allowing to set your options and save the file.
You can also just save a screen shot render using the menu (can't remember which actual menu item it's listed under).
