HI guys,
would you know I can do a hinge mate with this green (transparent) panel and the hinge assembly you see in the picture below?
Because I want to check to make sure the panel does not pinch into the black base so I want to check this hinge at every angle basically.
please let me know if you can help!
Mate it together as it would be assembled. Then make your hinge sub assembly flexible. You can move the cover through the angles needed for real world applications with an angle limit mate. Use collision detection to stop the motion if there's interference.
