I am reworking a machining job from 20 years ago when the parts were machined individually. I want to machine all the parts in one setup out of one piece of material. These parts are already solids in Solidworks. The attached is an assembly of the parts but Cam does not seem to work with assemblies. So, I was thinking of a multi-body part. Does any one know if this will work? OR Is there a better way?
I do not know if this will work but can you save the assembly as a part then use it in CAM?
