I need to replace one of the components in the drawing file so what I did was go to the parts file and replaced the component. Now the drawing file has a (?) where the component is suppose to appear. Is this fixable?
Can you please clarify something? My impression is that you've replaced a component in an Assembly, you have a drawing view (or views) of the original component in a Drawing, and you want to replace these drawing views with drawing views of the new component?
If yes, unless these components are very similar, such as the original component was saved to a new name and then modified, you might was well just go ahead and bite the bullet and delete the original drawing views and insert new ones of the new component.
Go back to the parts file and put the files back like they were. Open the drawing, and hopefully the references are okay. Now use the "Replace Model" function like I said in the other Discussion. In case it wasn't clear, you do that by right-clicking on the drawing view in the Drawing.
