MJMatt Juric01/04/2019
I've tried everything I can think of to change the color of a toolbox part and have zero luck. I have gone into the toolbox and changed the color as below. When I create a part a hex bolt it comes across as blue'ish. I went into the actual part and removed all appearances from the default config...came across as blue'ish. Removed all appearances from each body in the default config...Blue'ish.
I'm sure I'm doing something wrong as this seems like it should be a simple task, but I've been wrong on the "Seems like this should be a simple task" assumption in the past.
Any help would be appreciated
