Fifi Riri
Cut notches at each bends extremities on a sheet metal part for laser cut
Discussion created by Fifi Riri on Apr 1, 2019
Following this thread: Draw lines at each bend lines extremities on a sheet metal drawing for engraving
Here is a macro to add notches at each bends extremities on a sheet metal part.
It will add an Unfold and fold feature, and create a cut feature with fully defined triangles.
Option Explicit
Dim swPreviousSketchSeg As SldWorks.SketchSegment
Dim swFeat As SldWorks.Feature
Dim swSubFeat As SldWorks.Feature
Dim swFixedFace As SldWorks.Face2
Dim swBends() As SldWorks.Feature
Dim swFlatPatt As SldWorks.FlatPatternFeatureData
Dim swSketch As SldWorks.Sketch
Dim boolstatus As Boolean
Set swModel = swApp.ActiveDoc
Set swPreviousSketchSeg = Nothing
swModel.ClearSelection2 True
Dim i As Integer
Set swFeat = swModel.FirstFeature
While Not swFeat Is Nothing
'Debug.Print swFeat.Name & " " & swFeat.GetTypeName2
'get Fixed Face
If swFeat.GetTypeName2 = "FlatPattern" Then
Set swFlatPatt = swFeat.GetDefinition
swFlatPatt.AccessSelections swModel, Nothing
Set swFixedFace = swFlatPatt.FixedFace
swFlatPatt.ReleaseSelectionAccess
'get Bends
If swFeat.IsSuppressed = False Then
'Debug.Print swFeat.Name & " " & swFeat.GetTypeName2 & swFeat.IsSuppressed
Set swSubFeat = swFeat.GetFirstSubFeature
While Not swSubFeat Is Nothing
If swSubFeat.GetTypeName2 = "SketchBend" Or swSubFeat.GetTypeName2 = "OneBend" Or swSubFeat.GetTypeName2 = "UiFreeformBend" Then
ReDim Preserve swBends(i)
Set swBends(i) = swSubFeat
i = i + 1
Set swSubFeat = swSubFeat.GetNextSubFeature
Wend
Set swFeat = swFeat.GetNextFeature
Wend
'select fixed face and bends
boolstatus = swFixedFace.Select2(False, 1)
For i = 0 To UBound(swBends)
Set swFeat = swBends(i)
boolstatus = swFeat.Select2(True, 4)
Next
'insert Unfold feature
swModel.InsertSheetMetalUnfold
'create sketch
boolstatus = swFixedFace.Select2(False, -1)
swModel.SketchManager.InsertSketch True
swModel.SetAddToDB True
If swSubFeat.GetTypeName2 = "ProfileFeature" Then
Set swSketch = swSubFeat.GetSpecificFeature2
ProcessSketch swSketch
Set swSubFeat = swSubFeat.GetNextSubFeature()
Wend
Wend
swModel.SetAddToDB False
'create notch cut
Set swFeat = swModel.FeatureManager.FeatureCut3(True, False, False, 1, 0, 0.01, 0.01, False, False, False, False, 0, 0, False, False, False, False, True, True, True, True, True, False, 0, 0, False)
boolstatus = swFixedFace.Select2(True, 1)
Next
'insert Fold feature
swModel.InsertSheetMetalFold
Sub ProcessSketch(swSketch As SldWorks.Sketch)
Dim vSketchSegs As Variant
Dim vSketchSeg As Variant
Dim swSketchLine As SldWorks.SketchLine
Dim swSkStartPt As SldWorks.SketchPoint
Dim swSkEndPt As SldWorks.SketchPoint
vSketchSegs = swSketch.GetSketchSegments
For Each vSketchSeg In vSketchSegs
Set swSketchLine = vSketchSeg
If swSketchLine.IsBendLine Then
Set swSkStartPt = swSketchLine.GetStartPoint2
Set swSkEndPt = swSketchLine.GetEndPoint2
DrawTriangle swSkStartPt, swSkEndPt, swSketchLine
DrawTriangle swSkEndPt, swSkStartPt, swSketchLine
Next
Sub DrawTriangle(swSkPt1 As SldWorks.SketchPoint, swSkPt2 As SldWorks.SketchPoint, swSketchLine As SldWorks.SketchLine)
Dim swSketchSeg1 As SldWorks.SketchSegment, swSketchSeg2 As SldWorks.SketchSegment, swSketchSeg3 As SldWorks.SketchSegment
Dim swSketchRelationManager As SldWorks.SketchRelationManager
Dim swSketchRelation As SldWorks.SketchRelation
Dim X1 As Double, Y1 As Double, X2 As Double, Y2 As Double
Dim X3 As Double, Y3 As Double, X4 As Double, Y4 As Double
Dim Length As Double, Delta As Double
Dim swObjects(1) As Object
X1 = swSkPt1.X
Y1 = swSkPt1.Y
X2 = swSkPt2.X
Y2 = swSkPt2.Y
'set base triangle length to 1 mm
Delta = 0.001
Length = ((X2 - X1) ^ 2 + (Y2 - Y1) ^ 2) ^ 0.5
'create triangle sides
X3 = (X2 - X1) * Delta / Length + X1
Y3 = (Y2 - Y1) * Delta / Length + Y1
X4 = (Y2 - Y1) * Delta / 2 / Length + X1
Y4 = (X2 - X1) * Delta / 2 / Length + Y1
Set swSketchSeg1 = swModel.SketchManager.CreateLine(X3, Y3, 0#, X4, Y4, 0#)
X4 = -(Y2 - Y1) * Delta / 2 / Length + X1
Y4 = -(X2 - X1) * Delta / 2 / Length + Y1
Set swSketchSeg2 = swModel.SketchManager.CreateLine(X3, Y3, 0#, X4, Y4, 0#)
'create triangle base
X3 = (Y2 - Y1) * Delta / 2 / Length + X1
Y3 = (X2 - X1) * Delta / 2 / Length + Y1
Set swSketchSeg3 = swModel.SketchManager.CreateLine(X3, Y3, 0#, X4, Y4, 0#)
Set swSketch = swSketchSeg3.GetSketch
Set swSketchRelationManager = swSketch.RelationManager
'add equal length constraint between triangle sides
Set swObjects(0) = swSketchSeg1
Set swObjects(1) = swSketchSeg2
Set swSketchRelation = swSketchRelationManager.AddRelation(swObjects, swConstraintType_e.swConstraintType_SAMELENGTH)
'add middle constraint between triangle base and point
Set swObjects(0) = swSkPt1
Set swObjects(1) = swSketchSeg3
Set swSketchRelation = swSketchRelationManager.AddRelation(swObjects, swConstraintType_e.swConstraintType_ATMIDDLE)
'add perpendicular constraint between bend line and triangle base
Set swObjects(0) = swSketchLine
Set swSketchRelation = swSketchRelationManager.AddRelation(swObjects, swConstraintType_e.swConstraintType_PERPENDICULAR)
If swPreviousSketchSeg Is Nothing Then
'add triangle base dimension
Dim swMathUtil As SldWorks.MathUtility
Dim swModelToSketchXForm As SldWorks.MathTransform
Set swModelToSketchXForm = swSketch.ModelToSketchTransform.Inverse
Set swMathUtil = swApp.GetMathUtility
Dim nPt(2) As Double
Dim vPt As Variant
nPt(0) = -(X2 - X1) * 0.001 / Length + X1
nPt(1) = -(Y2 - Y1) * 0.001 / Length + Y1
nPt(2) = 0
vPt = nPt
Dim swPt As SldWorks.MathPoint
Set swPt = swMathUtil.CreatePoint(vPt)
Set swPt = swPt.MultiplyTransform(swModelToSketchXForm)
swSketchSeg3.Select4 False, Nothing
swApp.SetUserPreferenceToggle swUserPreferenceToggle_e.swInputDimValOnCreate, False
Dim myDisplayDim As SldWorks.DisplayDimension
Set myDisplayDim = swModel.AddDimension2(swPt.ArrayData(0), swPt.ArrayData(1), swPt.ArrayData(2))
swApp.SetUserPreferenceToggle swUserPreferenceToggle_e.swInputDimValOnCreate, True
Else
'add equal length constraint between triangle base and previous triangle base
Set swObjects(0) = swPreviousSketchSeg
'add equal length constraint between triangle base and side
'save base triangle to constrain next triangle
Set swPreviousSketchSeg = swSketchSeg3
