I'm having an issue when printing to PDF. For example I'll draw a rectangle using the draw tool in SWE on a scheme sheet. I'll change the line weight of that rectangle to something large so that the line appears thick/bold. When I print to PDF the rectangle lines are as thin as all the other lines in the drawing. I tried toggling the "Line Weight" (Ctrl-5) in Adobe reader and that makes no difference. I also know about the show/hide line weights in SWE (F10) which whether that's on or not makes no difference.
Looking for help on how to print PDFs with true line weight/thickness.
Thanks.
Another thought: When you got to Export to a *.pdf, do you 'Plot with Style' - I use Tracecad.tps
