Format BOM for Excel Export
Question asked by David Hales on Mar 29, 2019
Latest reply on Mar 29, 2019 by Artem Taturevych
I found the original macro online, and I expanded upon it quite a bit.  It takes a drawing BOM and saves it out as a CSV file, which is then converted to an Excel file.
My Problem:  If the description, or another column in my BOM has a comma in it, that throws off the CSV file, and I get an extra column when I open it in Excel.  I get the BOM through GetTableAnnotations.  My thought was to try and loop through the annotations and replace a comma with nothing for each cell string, but I cant' figure out how to navigate through annotations.  Can someone please help me with this loop?
Sub Export_BOM_As_Excel_Main()
    On Error Resume Next
    Dim swTableAnn As SldWorks.TableAnnotation
    Dim swBomFeature As SldWorks.BomFeature
    Dim swAnn As SldWorks.Annotation
    Dim ActiveDocumentPath As String
    Dim vTableArr  As Variant
    Dim vTable As Variant
    Dim retval As Boolean
    Dim CSVFile As String
    Dim swCustPropMgr As SldWorks.CustomPropertyManager
    Dim ValOut As String
    Dim DwgRev As String
    Set swModel = swApp.ActiveDoc
    Set swCustPropMgr = swModel.Extension.CustomPropertyManager("")
    ActiveDocumentPath = swModel.GetPathName ' get filename for evaluation
    If swModel Is Nothing Then ' checks to see if something is open
        MsgBox "No Drawing Loaded!", vbCritical, "Drawing Load Error"
        Exit Sub
    ElseIf swModel.GetType <> 3 Then ' checks to make sure drawing is open
        MsgBox "Current Document Is Not A Drawing!", vbCritical, "Drawing Macro Only!"
        Exit Sub
    ElseIf ActiveDocumentPath = "" Then ' check to make sure drawing has been saved
        MsgBox "Save Drawing First!", vbCritical, "Save Document Error"
        Exit Sub
    swCustPropMgr.Get5 "REVISION", True, ValOut, DwgRev, False ' get revision of drawing
    TraverseFeatureTree ' traverse tree and select BOM
    Set swBomFeature = swSelMgr.GetSelectedObject5(1) ' Make sure a BOM is selected in the feature manager design tree
    If swBomFeature Is Nothing Then Exit Sub
    vTableArr = swBomFeature.GetTableAnnotations
    For Each vTable In vTableArr
        Set swTableAnn = vTable ' Got BOM as table annotation
    Next vTable
    CSVFile = "C:\" & Left(swModel.GetTitle, InStrRev(swModel.GetTitle, " Sheet") - 3) & "_" & DwgRev & ".csv" ' Rename BOM with Rev and .csv file extension
    ' Save csv file. If you save it as an xlsx file and try to open it in Excel and it will tell you that it is an text file.
    ' This way it actually saves as a csv file and no message box will pop up
    retval = swTableAnn.SaveAsText(CSVFile, ",")
    Dim FileToKill As String
    FileToKill = Left(CSVFile, Len(CSVFile) - 3) & "xlsx" ' existing excel file
    If Dir(FileToKill) <> "" Then Kill FileToKill ' delete if exists
    Set xlApp = CreateObject("Excel.Application")
    xlApp.Visible = False
    Set xlWB = xlApp.Workbooks.Open(CSVFile) ' Open the CSV file
    With xlWB.ActiveSheet
        .Range("A1").Value = "REV" ' rename header
        .Cells.EntireColumn.AutoFit ' fit column width
    End With
    xlWB.SaveAs Left(CSVFile, Len(CSVFile) - 3) & "xlsx", 51 ' and save as xlsx
    xlApp.Quit
    Kill CSVFile ' Get rid of .csv file
Sub TraverseFeatureTree() ' You could even add arguments
    Dim swFeature As SldWorks.Feature
    Dim ModelDocType As Long
    Dim FeatureName As String
    Set swApp = Application.SldWorks ' Connect to SW
    Set swModel = swApp.ActiveDoc ' Get active document
    swModel.ClearSelection ' Clear any selection
    ModelDocType = swModel.GetType ' Get document type
    Set swFeature = swModel.FirstFeature ' Get first feature in feature tree
        While Not swFeature Is Nothing
          FeatureName = swFeature.Name
          If InStr(UCase(FeatureName), "EXCLUDE") Then ' bom excluded for hose kits
            'do nothing
            Else
                If InStr(UCase(FeatureName), "BILL OF MATERIALS") Then
                    swFeature.Select True ' Select the BOM
                    Exit Sub
            Set swFeature = swFeature.GetNextFeature ' Get next feature
        Wend
