Hi to everyone, i was working in an assembly and i have one part number repeated in my design tree but when i want to see one of this repeated part numbers im not being able to see one of them, neither i cant select it (just one of them) i use a platform connected to solid works to order the parts of my designs and in this platform i neither can see this part (one of them) i just see one in mi cart.
I have attached some pictures in order you be able to see this issue:
This is the part i can select, the another one im not being able to see it or select it or nothing
This is the part i cant select
Ill really appreciate you answers or help
EDITED BY MODERATOR: Moved to the Assemblies space. Please try to post in the appropriate space when creating posts.
Not sure if this will help but if you use Select Identical Components under the Select pull down menu, you can then grab all of them at once by clicking on just one. It will at least identify where it exists in the tree.
